Hi.
While on the UiPath Studio recorder, pressing esc to stop recording exits the recording, but does not record.
Can you help me with this.
Thank you
Hi.
Thank you
which type of recording are you using? Is it Basic, Desktop, Web or Image?
The steps taken up by me are:
Thanks
Latika
Very thank, Latika10011740.
Selecting esc or F2 does not record.
Selecting esc closes the open windows. It never reaches the save option (it is still disabled).
Will I have to reinstall UiPaht Studio?
Thakt
If it is not problem with close or recording can you uninstall Uipath and re install it once.
Thanks
Latika
I already solved. Thank you very much
