Hello every body
I have a problem with my Type info activity
When the robot write a value like this PRJ4114 in the field My project in the my web application.
There is an another field with automatic Filling;
The robot get the value of my project number like this PRJ411 and not the value of PRJ4114
The value of PRJ411 is different of the value of PRJ4114
Robot get this
Instead of this
I given the necessary time to activity for be exucte. See the Screenshot
This problem is not for all of my Project number, it come from time to time not always.
I share whit you my project
Main.xaml (197.0 KB)
Try giving delay between keys in Properties pane of Type into Activity
I tried this, but I have the same problem. there is a another type of activity to write on the field on the web application?
lakshman
(Ganta lakshman)
March 26, 2019, 1:36am
4
@Slimane_OUZIALA ,
Try once with Set Text activity.
varunk
(Varun Kumar)
March 26, 2019, 4:48am
5
Hi @Slimane_OUZIALA ,
Yes try with set text
or else use type into & pass the selector dynamically
anil5
(Anil Kumar Bandam)
March 26, 2019, 5:00am
6
Hi @Slimane_OUZIALA
Try with Default method or simulate property
And give Click before typing and delay between keys as 100
@Slimane_OUZIALA ,
Did you try this?
Create a variable and assign value to variable and pass that variable to Project field.
Cheers,
Pankaj
@lakshman & @varunk Thank you for your answers, I tried it but the same problem, I have the a problem with automatic filling
I will try it thank you @anil5
can you try breaking your string into chunks ie sending 1 character or maybe 2-3 character at a time to see if this issue persists.
i experience something like this with vba sendkeys in the past and i am not sure if type-into uses the same implementation.
@garywjd91
In my case the variable to split contains 6 or 8 caracters, number or letters.
how to split this variable to créate 6 others variables ?
Thank you
Thank you every body,
I resolved this issue with this method,
I get my Variable and I split it to one Char by time.
I assign my Variable to Var.ToCharArray() and I Loop all my items in the my Var
finally I send to my Feild Item by item.
The solution in attach
I update the topic to resolved.
Main.xaml (7.3 KB)
glad that you managed to solve this
system
(system)
Closed
March 30, 2019, 2:03pm
14
