Want to check if there is really problem with UIpath Selector when using UI Explorer in SAP Business Client (NWBC). I spent considerable time reinstalling java, SAP client etc since i was not able to select any element in the UI screen using the UIPath explorer.
But then i open the SAP GUI client and see that UIpath Explorer is able to select the element and hence identify correct selector like a charm. My machine is windows 10 and using uipath version 2018.4.3.
I also see Limitation Notes on UIpath site https://studio.uipath.com/docs/enabling-sap-gui-scripting
"SAP automation can be performed with two clients, namely SAP GUI for Windows and SAP Business Client (NWBC). However, the latter client has some limitations in the SAP GUI Scripting engine, which is the technology used by UiPath to automate SAP applications. "
Not sure what is the real problem with SAP Business Client (NWBC), but want to check if others are also facing same problem.
