When I try to run process from production machine, I get error
“C:\Users\evaprod\Desktop>“C:\Program Files (x86)\UiPath\Studio\UiRobot.exe” -file “C:\Robot\PlasiraniSaldirani\lib\net45\Main.xaml” /executor /monitored
The feed ‘Official [https://www.myget.org/F/workflow/]’ lists package ‘System.Buffers.4.5.0’ but multiple attempts to download the nupkg have failed. The feed is either invalid or required packages were removed while the current operation was in progress. Verify the package exists on the feed and try again.”
I have to nitice that everything was OK while running it on the Uipath DEV server.
Does anyone have an idea what is the problem in this case?
You may not have internet access in the PROD machine to download the package. Copy the package from your DEV machine to the PROD machine, then try once.
" The feed ‘Official [https://www.myget.org/F/workflow/]’ lists package ‘System.Memory.4.5.3’ but multiple attempts to download the nupkg have failed. The feed is either invalid or required packages were removed while the current operation was in progress. Verify the package exists on the feed and try again."
But how to change it? I don’t know why this version of package from the error above is incorrect…
The same version is on the DEV enviroment, too, and it works correctly…
“The feed ‘Official [https://www.myget.org/F/workflow/]’ lists package ‘System.Memory.4.5.3’ but multiple attempts to download the nupkg have failed. The feed is either invalid or required packages were removed while the current operation was in progress. Verify the package exists on the feed and try again.”
Check whether this package is there or not in the PROD machine. If it is there then in your DEV machine uninstall it and reinstall the latest version of this package. Else in the same production machine check with a different user account for the same process and package.
