I’m trying to make an API request from Invoke Code activity (C#). The code looks like this:
var client = new RestClient();
client.BaseUrl = new Uri("https://api.totango.com/api/v1/search/accounts");
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/x-www-form-urlencoded");
request.RequestFormat = DataFormat.Json;
string abc;
request.AddBody(new
abc = "123"
IRestResponse response = client.ExecuteRequestAsync(request);
Console.WriteLine(response.Content);
I’m getting the following errors:
CS0246: The type or namespace “RestRequest” could not be found
CS0103: The name “DataFormat” does not exist in current context
CS0246: The type or namespace “IRestResponse” could not be found
All the three items named in errors are part of the RestSharp library. I see “RestSharp” in the list of imported namespaces in Studio. But, it seems that the code in Invoke Code activity cannot access RestSharp. Does anyone have any idea how to fix this?
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Meet us and our users on our Community Slack and ask your question there.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
The only version of restsharp I have been able to use successfully in UIPath is version 106.3.1.
Please see example below:
var client = new RestSharp.RestClient();
client.BaseUrl = new Uri(varUrl);
var request = new RestSharp.RestRequest(RestSharp.Method.POST);
client.FollowRedirects=false;
request.AddCookie(name, value);
request.AddHeader(name,value);
request.AddParameter(name,value);
IRestResponse response = client.Execute(request);
