I was trying to build and publish library working on 2018.4 with 2019.9.0 but I’m unable to publish it due to an error:
The type ‘IEnumerable<>’ is defined in an assembly that is not referenced.
You must add a reference to assembly ‘netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’.
Studio shows no error and System.Collections are in Imports. What is more I am able to publish it as a process but not as a library.
Have anyone experienced similar problem ? What may be the cause of that problem?
Hi @bdziedzi,
Are both Studios running the same version of packages? Please also check if all dependencies used in 2018.4 are imported in 2019.9 as well (including Imports tab).
At first open of 2018.4 project, (in 2019.9.0 studio) it has keept all packages in original versions without showing any conflicts or problems.
I had also tried to upgrade all packages to the latest versions and I was also trying to recrate project.json by deleting it and opening in 2019 Studio.
I was unable to publish it on all atempts .
Currently, I have found that the problem is with UiPath.IntelligentOCR.Activities. After removing that dependency and activities, from project, it was published without any errors.
I have created a fresh new library project, than added dependency to UiPath.IntelligentOCR.Activities and I cant publish it as Library without an error.
This problem looks similar to the one described here:
