i have a problem with opening a browser window in the Picture in Picture Mode in UIPath Studio.
The task is fairly easy, the robot should just start a browser. Unfortunately though, the robots gets stuck at the open browser activity although the browser window opened completely normal. I`m encountered with this problem only in PiP-Mode. I also used different browsers…same result.
I noticed that the browser icon on the windows-bar in the PiP flashed yellow after opening it.
Thanks for the hint: After a while, I got the following error-message:
With the error message I was able to find a solution. If I go to the “Open Browser” activity and change the settings in “UserDataFolderMode” in the properties to “Default Folder” it works completely fine. I don`t no why but it works
