I am using CVScope for automating the process on remote desktop.
On the remote, I’m using one private app. The problem is that that cv works on everything except on the table where I need to click on a specific row. UiPath doesn’t recognize that table. I try with CV click but sometimes click is correct, sometimes it isn’t. Then I find a solution with Tesseract OCR but isn’t working.
I can recognize a row because when I click Serch little arow show me row that I need click and the other way is to find the correct id (I have id saved in Variable).
Can I in some way change Descriptor and set my Variable in it, or is there some other way to click on the correct row. Please help.
Ty in advance.
