Hello,
I’ve got a problem connecting my company’s instance of ChatGPT on Azure.
Usually, I would use the preexisting connector “OpenAI V1 Compliant LLM”, as I’m using an endpoint and API key.
The problem is that it requires the URL to have the endpoint “/models” - so it can check what models are deployed.
Due to company policy, the requests are routed through PowerProxy, and the link is not standard - I have a specific URL that I have to use:
https://powerproxy.mycompany.com/openai/deployments//chat/completions?api-version=
I found a way to create a custom connector to use this specific endpoint. I also tried and succeeded in using a simple HTTP request.
My issue and question is - How can I use my LLM as a model for Agents built in Studio Cloud? Is it even possible? If I can’t change the way we are connecting to the model, are there any workarounds?
Thanks in advance
