Problem with changing ID in selector
Inside my object: Type Into, the ID changes every time I click on the intended field. Is there a way for UIPath to type into the selected field even when it changes its ID in selector?
Also, I tried changing the ID to a wild card, but it didn’t change anything, it got worse. It just closed the pop up entirely.
Hello Carlo,
Try to use anchor base,i guess it will help,
Using find element and type into…Hope this helps
Even if I anchor it, it doesn’t change anything. :frowning:
I’m using a find element, but that too is looking up an ID that will change every time the page refreshes.
Hello Carlo,
I tried to use an Anchor Base Object, but it’s returning an error:
Anchor Base for First Name: Value does not fall within the expected range.
