Problem with "appand range"
hello :slight_smile:
I need to place certain data in the same sheet one below the other. Using the append Range activity, the required format is obtained, but a duplicate sheet is created when the data column is “PIN”
Does anyone know how this can be done so that everything is in one sheet? :frowning:
@dvojinovic
I believe there is a space…check the same…
Two sheets cannot have same name
Hi @dvojinovic
Check the sheet name in append range. Just trim it. Hope this will solve your issue.
Thanks
Thank you, it worked :slight_smile:
