Problem using ServiceNow activities with IntegrationService
I have a IntegrationService for ServiceNow, connection is successful.
When I try to use the activity Get Record, I get error such as:
The object ‘sc_request’ is no longer accessible on the current connection. Please verify your permissions, or choose a valid object from this connection, or select a connection that includes this object. Error code: DAP-DT-2002.
Configuration on ServiceNow has been reviewed and all seems ok.
What could be the issue?
@fabianBMCO
Can you share a screenshot how you configured the activity. Also check if the record is indeed accessible to the account using integration services connection.
@fabianBMCO
Welcome to the community
please check this
cheers
Hi @fabianBMCO ,
this error occurs when the Integration user lacks permission to access the ServiceNow object metadata, not just connection. UiPath documentation recommends:
Read access on sys_db_obj and its fields,
CRUD rights on the target table (sc_request),
Web service access (ws_access)** on the object.
Without these, Integration Service cannot expose the object in activities and throws DAP-DT-2002.
