Problem- Robot is not visible to starr the job in orchestrator
Robot is invisible to start the job in orchestrator. But i can able to create environment.
@Bapum There is a Possible chance that you have the Robot Type as Studio or StudioPro. Change the Robot Type to Unattended and then check if the Robot appears in the Jobs Section.
Thank you so much, it worked
Is there anyway to download a process from orchestrater and edit it.
@Bapum Actually If the Orchestrator is connected to your Machine, then you should be able to get the Process in the Designated Folder
“C:\Users\[UserName]\.nuget\packages\[PackageName/ProcessName]”
