Problem in Data Scraping detecting it as a header when it should not be
Hello ,
I just want to ask if there is a way where I can extract the data on my file( Please see attached images) The first row is being detected as a column name/header when it should not be.
@jdlivara
Welcome to forums
If you are using to write to CSV / Excel then in that activity, disable Add Headers options, then it will detect as a header
Hope this helps you
Follow Link
Thanks
Hello,
Thank your for the but it doesnwork, I need the first row, below what happens when I disable the head option on the write range activity. The 1st row is gone
This is result
This is the result when I include the Header, it creates another header
@jdlivara
In Read Range activity of CSV / Excel, remove the check mark property of Add headers
so that it will not read as header
Check below for your reference
https://forum.uipath.com/t/convert-date-time-format-tutorial/242670/2
Hope this helps you
Thanks
