Problem Connecting Robot to Orchestrator
Hi I have create one flow and published successfully.I can’t able to do, getting following error. I have entered my machine key and URL and connect my robot still i’m getting unlicensed error. Because of this i can’t get my process name in the list
Hi @vivek_sivam
Check below post the New requirement for connecting orchestrator
Hope this helps
Thanks
Check if robot is created for the user ID you are currently logged in.
Nithin
Thanks @Nithin_P and @Srini84
I’m getting different error like image
But i have enabled the extensions still i’m facing this issues
Did the robot get licensed ?
