Possible to turn off monitor while scrape is running?
I’ve built a scrape that works fine as long as my monitor is on. If I turn the monitor off, the process stalls until I turn the monitor back on.
Is there any way to run a scrape with the monitor switched off?
hi @dwilson
Yes there is a way to run your published workflow even the monitor is switched off by using Orchestrator. By using this you will be able to remotely run this process on a machine .
For further information you can go through with these links:
Thanks& Regards…!!
