Please help to prevent replace in data excel in same location
Main.xaml (38.5 KB)
dear
friends
please check above file and help
i need to write next data in to next excel address B2
BUT all data replace in A1
PLEASE HELP FRIENDS
Main (3).xaml (38.9 KB)
Check this file. The problem is you inserted write csv activity and Build datatable activity inside for each row.
please help to adjust
Did you ran the file i attached within the previous reply.
wait friend
can you please come though team viwer
Ok looks like you are using the older version of uipath…Just move the build datatable activity and write csv activity to outside of for each row…Just place build datatable activity to the top of for each row and write csv to the bottom of for each row
1066601216
8309
please kindly logging
ITS WORKING 100%
THANK YOU VERY MUCH …!!!
dear friend
could you please help me to connect oracle db with ui path please help
