isnt it the attached is not the appropriate way of preparing Body content!
No…instead use bodyishtml in the properties and use<br> where ever you need a line break
Eg: "Hi Team,<br><br>attached is weekly report <br><br>Regards,<br>RPA Bot"
Also the mistake in yours is you closed the double quotes on first line only and open a new one on line 4 which is wrong again…everything should be inside quotes only except the variables you need…for variable you did correct
check the reference
You should be passing variable like this.
String.Format("Hello There, Your task has been completed. {0}", strFinal)
Thanks,
Ashok ![]()
You haven’t provided double quotes and concatenation with the strings, use the below one,
"Hi Team,
Attached is the weekly trouble ticket report for thie week of April "+strFinal1+"
Regards
Automation Team"
Hope it helps!!
