Hi All
I have a very simple rookie question.
After having worked so far with Orchestrator using a tenant on https://platform.uipath.com I am now moving in to using Orchestrator on internal server.
So I have received a test license from UiPath and completed the first step by doing a basic installation.
The Orchestrator is up and running, I have made my first login using these credentials:
Tenant:
Login: admin
Password: 890iop ( default password which I then changed at first time login)
So next step would be to create a tenant.
By looking into Orchestrator documentation ( Managing system administrators ) I should click Settings and on the Settings page be able to choose Application Tab.
But there is no Application tab when I look at my Settings page:
Can anyone help me find documentation on how to do this or explain it to me?
I am aware that on the Orchestrator Community Edition ( https://platform.uipath.com ), there is a link on the Login page = “Become a Tenant” where you signup and have your Tenant created, but this does not seem to be the same when you work with Orchestrator installed on own server.
Thanks in advance
Tom
