Oracle application click element throwing issue help me out
after login into oracle page i want to go to below module using IE(see attachment) click on rates , help me out how can i design a bot for this. i used click option , it is throwng error like cannot find ui element for this browser afteri close the browser and run the bot
please help me out for this case.
Some web applications have auto generated selectors so differ every time you load the page.
Try to use UiExplorer to identify if you can attach to live element.
Otherwise you may have to identify another way to access that particular route, i.e. key presses or using click text etc.
You were almost done
—like once after logging in it will go to a NEW PAGE that is a NEW WINDOW so we need to use either ATTACH BROWSER or ATTACH WINDOW activity and inside that keep the CLICK activity
Also enable the Simulate click property in the property panel of click activity
Cheers @senthil.it89
it is not working palani, it is still throwing error as same
Hmm…Actually it would buddy, is simulate click property enabled
Fine
If possible can I see the selector if the click activity
@senthil.it89
- error while running
image - selector window
kindly check whether the selector has any dynamic value in it
Like Click once the element and get the selector
And again close the application and open, clcik on the same element and get the selector
Compare them and we will Be finding the selector
difference
I hope parent id will be differing
If so replace the dynamic part with wild card *
yeah it worked ad dynamic value by passing wildcard
many thanks
Awesome
after clicking on rates - security warning popup window should appear— in my case bot is executed but popup warning not runing
i have designed a bot to do the check box selection , but iam getting error like below.
Attach window would work on this
But I hope there must be some issue with the selector
Fine
We can try with GetActive Window activity where inside that container place this click activities
in this new popup window i have to press ok or enter in window,
then in the below popup window i have to click cancle,
then i have double click currencies,double click daily
help me to design the bot
- my design
image -error throwing
hello, i have created a robot using UiPath studiox.
the robot runs the oracle application fine with all the steps i need. but once it get to the parameters which i need to write the date from to the parameters window disappear.
so, the remaining of the robot doesn’t complete and the robot stop.
how do I fix this? please.
i am really appreciate the help.
You shouldn’t dig up 4 year old posts, you should create a new post with your question.
