Obtaining An Access Token From Postman Using The Postman Authorization Flow Does Not Work
When trying to obtain an Access Token through the Postman Authorization flow does not work and returns the following error "Authentication failed. Couldn't complete authentication. Check the Postman Console for more details." .
Below is an example of a configuration used that did not work and resulted in the error:
Resolution:
  • Pass the parameters directly into the body just like in the example below:
