Not able to see body of FOR EACH and FOR EACH ROW in main sequence
Hi everyone,
I am not able to see body of for each activity and for each row activity in my main sequence but i am able to see in outline panel. But i want to see without outline panel.
Because i want to edit in future. Now i am able to run the process but i want to see the body of for each and for each row activities.
Please help…
Thanks in advance.
@User_98
you used a library activities
so, it canot appear the body of for each and for each row in data table.
Collapse and then add the activity ( For Each and for each row data table )in the main sequence.
cheers…!
No i did not use library activities, while developing i have used system activities only but recently i have signed into another new account and published to orchestrator Since then this problem occurs…
It is showing like this only for this process for remaining processes i am able to see complete activity without outline panel.
Please help…
@User_98
i think so any packages missed in your particular project
or
Close and reopen UiPath Studio, then re-open the project. If the issue persists, consider restarting your machine. This can often resolve display-related glitches.
If the problem persists, consider checking for any updates to UiPath Studio and applying them. Outdated versions may have bugs that have been addressed in newer releases.
I have installed system.activities package now i am able to see it.
Thank you @sai_gupta for helping…
Best Regards,
Roman reigns.
