Not able to loop through list of strings and split which as more than 2 spaces
wordpress.pdf (42.6 KB) as in pdf
it has “demo - slices invoices” “order number” “12345”
i need to get strings like this after reading pdf and splitting it
Hi
what activity did you use ?
was it read pdf with OCR or screen scarpping ?
read pdf text
Hi @Pradeep_Shiv,
split the result (Result.Split({environment.NewLine},stringsplitoptions.RemoveEmptyEntries)) with newline and extract the data through using the regular expressions
How to loop through lists and split which has more than 2 or more spaces chechk this post this is my problem
here you go buddy readpdf.zip (50.7 KB)
hope its resolved
Cheers @Pradeep_Shiv
hey , please go through this code @Palaniyappanwordpress.pdf (42.6 KB) i want it likes this i want to extract every row and store it in list of strings test11.xaml (18.0 KB)
run this file once and i should get the output same for every row, i’m splitting on basis of spaces if there is one space i need it as same one block if more spaces in between ive to delete and get the next block sample pdf is attached please check
thanks
fine buddy
pradpp.zip (49.7 KB)
