looks like Oracle. Did you enabled JAVA extension?
were you able to capture any element on this application? try installing JAVA extension and let me know
You can solve this error by trying below,
- Indicate the cross section with proper anchors and in activity properties give wait for read is complete
- use check app state to ensure that cross section is avaialable or not
- if above both not worked use CV click
try and let me know if any issues
Happy automation!!
@SSD,
Use prebuilt activity Close Window for this which is more reliable than Click
i Couldnt find this activity in UiPath
if you didn’t get the solution by following above options
use Close window activity to close that it will be available in classic. Follow belwo screen shot to get the activity
@SSD,
It’s a classic activity. Check the filter in Activities panel to show classic activities in the panel like shown by @yedukondaluaregala
