Need to update cell in excel after finding row number using combination of more than two column values
FirstName LastName EmployeeID
Ram Kumar
Ram Sharma
Ram Singh
I have an excel with above data. I need to update the cell in employeeID column for combination of FirstName and LastName. Basically i need to find the row number for combination of FirstName and LastName.
in for each row in datatable activity, set
CurrentRow("EmployeeID") = CurrentRow("FirstName").ToString+CurrentRow("LastName").ToString
Hey @Shashi123
I guess you are looking for something similar - Get row number in excel for combination of Column Data - #4 by Nithinkrishna
Hope this helps
Thanks
#nK
No Sir. What i am looking is getting row number. Actually i need the row number in an excel where input is Firstname and lastname. So basically i want to find row number where FirstName is Ram and LastName is Kumar. Depending upon input which is FirstName and LastName i want row number.
Hey @Shashi123
Yep, the above link which has the code will return you index from which you need to just increment by one +1
Thanks
#nK
Hey @Shashi123
Just posting the sample below,
int_ExcelRowIndex = dt.Rows.AsEnumerable.Select(Function(obj) (obj("Firstname").ToString + obj("Lastname").ToString)).ToList().IndexOf("TestName") + 2
Actually it will be +2 considering the headers, as updated above
Hope this helps.
Thanks
#nK
Hi Sir,
What is IndexOf(“TestName”) in the code
Hey @Shashi123
TestName is just the name value to compare, you can use your original name
IndexOf will give you the row index
Thanks
#nK
Thank you sir for the help. What if i have the input in string format. Like i have Ram and Kumar as input. how should the formula look to get row number
Hey @Shashi123
Just concat RamVar + KumarVar and pass it in the indexOf function argument.
Thanks
#nK
I am getting an error which says AsEnumerable is not a member of System.Data.DatarowCollection
Hey @Shashi123
That’s due to import issue, okay just replace AsEnumerable with Rows
Thanks
#nK
Did the same. but still getting the error. If it is possible can u send me a xaml file with the code please. It would be a great help.
Thanks and Advance
Okay sure @Shashi123
Hey @Shashi123
Here you go…
nmnithinkrishna_XlRowIdxForMultiColMatch_08May2022.zip (8.3 KB)
Hope that helps.
Thanks
#nK
