I need to replace some text in my word file which might be greater than 255, as word file doesn’t replace text greater than 255, I am using .Substring method to divide the string, I am stuck at a part. And unsure on how to add the string in correct position after summation. Attaching sample xaml and word file. Need to replace input with the text given
Hi @Neha_Kumari1 , here’s a crudely implemented solution just to show that it will work and you get the general idea… You can refine it by doing a for loop for each text part. I have excluded part 4 as that part is still more than 255. February Sales.docx (18.9 KB) Test_Mod.xaml (29.1 KB)
