Need regex expression to scrape particular data from e mail body
@Aleem_Khan ,
Follow these steps,
Use Matches activity, and select RegEx as Email.
This will fetch all the email addresses present in that string.
kindly mark it as a solution that would be helpful to others for further reference, and also the query will get closed.
@90s_Developer
Hi @Aleem_Khan,
Can you update me regarding this query?
If your issue is solved, kindly mark it as a solution that would be helpful to others for further reference, and also the query will get closed.
@90s_Developer
HI @Aleem_Khan
For Example 1:
regex101: build, test, and debug regex
For Example 2:
You need to use split(RegexVarible,Environment.NewLine) to store all the emails in the array and you can use them by looping or incrementing.
For Example 3:
Can you send any constant word that is right below the table?
I will send you the expression
Hope this helps
Regards
Sudharsan
An also send the example 3 table as text format with the exact format of space by setting preserve format as true in read PDF text and use write test file and copy the table part and send here
Regards
Sudharsan
First try to separate the whole table as separate string like this
And use the following regex to get the table values
Note: You need to choose regex option as insensitive in matches activity if you use matches activity
if you use expression you need to give " ,Regexoption.insensitive "after the pattern
For splitting and saving in excel follow the steps or workflow in this thread
Hope this Helps
Regards
Sudharsan
Thank you so much for your effort I really appreciate I use email extraction to fetch email id from email body
Hi @Aleem_Khan,
If your issue is solved based on the solutions which were given in the above replies by us, kindly mark it as a solution to close this query else it would be in the active state until it mark as a solution to any one of the replies.
@90s_Developer
