I created docker image using below instructions
FROM Microsoft Artifact Registry
ADD https://download.uipath.com/UiPathStudio.msi C:\temp\UiPathStudio.msi
*RUN PowerShell -Command New-Item -Path “C:\” -ItemType “directory” -Name “UiPath”; *
** Start-Process C:\temp\UiPathStudio.msi -ArgumentList ‘ADDLOCAL=DesktopFeature,Robot,Studio APPLICATIONFOLDER=C:\UiPath /quiet’ -Wait; **
ADD / c:\temp\*
CMD [“cmd”]
After creating docker image I ran the docker container using below command
docker run --network “Default Switch” -it testdockerrobot cmd
After this step command prompt opened inside the container and I ran the below command inside the container
uirobot.exe -f “c:\temp\Main.xaml”
Main.Xaml contains only Writeline.
When I run above command UIrobot.exe is throwing "error occurred " message. There is no log and no information available about the underlying error. Can someone please help me to resolve the issue?
Is anyone ran the Robot inside the container? If yes, Am I following the correct steps to trigger the robot?
