Hi all, I’m trying to use Get Outlook Meil Message to export date and subject of the email but i’m keep getting this error, does anyone have a fix to this problem? Thanks
@Anh_Duy_Nguyen, can you leave the "mailFoleder" property empty and run your workflow, because i assume by default its going to look at the inbox folder.
