Need help with how to zoom an application in Uipath
Hi Team ,
I am New to UiPath, Currently exploring web automation.
Can anyone tell me how to zoom current tab.
Hey @Hossain,
Welcome to UiPath Community.
Use Keyboard Shortcuts activity targeting the whole browser window and send Ctrl + “+” to zoom in, Ctrl + “-” to zoom out, or Ctrl + “0” to reset zoom.
Wishing you a very happy start with UiPath
Hi @Hossain,
You can refer to this community thread
@Jakir
Welcome to the community
any specific reason you want to do this? that too in a web studio as while running anyways it would run unattended
cheers
cheers
Hi @Anil_G,
I am working with get text, so while it is in 50% resulation it is not able to get the number properly inside of 3 it is taking 8 but while I am resetting to 100% it is working fine.
Can I you the suggestion by @Mir.Jasimuddin ?
Use get text or get attribute not ocr. Resolution or zoom should not have impact on this.
Thank you all this is working
