Need help with extracting a particular substring or group of substring values from a given Input
I have to extract a particular name from the “VirtualName” attribute on a UI Field.
The attribute name keeps changing, two of the examples are:
  1. 40364794 8 MOTON 270 270 D 3 D
  2. 40125394 9 INNER INVESTOR SERVICES T 276 276 D 1 D
In both the examples mentioned above, I need two outputs
  1. The number (270 in first example and 276 in second example)
  2. The complete Name (‘MOTON’ in first example and INNER INVESTOR SERVICES’ in second example)
How can I get these 2 substrings?
I need a common regular expression, because the names and numbers keep changing
the parts in bold are they always a static length each time?
HI @Ruchita_Patil
Checkout this expressions
System.Text.RegularExpressions.Regex.Match(InputStr," [A-Z]{2,}").ToString.Trim
System.Text.RegularExpressions.Regex.Match(InputStr,"\d+(?=\s[A-Z]{1}\s\d\s)").ToString
Regards
Sudharsan
Updated one @Ruchita_Patil
System.Text.RegularExpressions.Regex.Match(InputStr,"(?<=\d)[A-Z ]+(?=\d+\s\d+)").ToString.Trim
Regards
Sudharsan
Hi @Sudharsan_Ka
Thank you for this, but I do not want the last letter T
Hi @rmorgan
No, The numbers 8 and 9 might change, can be 11 and 12 as well
