Hi There,
I am new to UiPath & don’t have any technical background.
Trying to follow video from UiPath academy, but the options do not match with the version I am using. Can someone who has insight help me here…
TIA
Hi There,
TIA
Hi @Srini84, I am trying to write cell. But do not see option as indicated in academy version. I am lost.
Thanks
Hi @bini
Above screen which you show was the StudioX automation, but below screen you are trying is on Studio Pro.
So you need to change your profile to Pro-> StudioX
Follow the steps to change to StudioX from Pro
Once you select Studio X, It will restarts and you are fine to go
Mark as solution, If this helps you
Thanks
