Need help. Unable to initiate a click
I am trying to click on “21501510.ASM” it is in div tag and the selector value changes after every reload. Its selector is
<html title=‘Exter’ />
<webctrl parentid=‘ember1267’ tag=‘SPAN’ />
there are other element in the page with the same “parentid” i.e “ember*”. so making it live does not help. I am trying to use Anchor base by making “number” as anchor and initiate a click on “21501510.ASM”. the number “21501510” changes with different input values.
So what activity to use inside anchor base.
Hey @devbrath
I have an internal app that uses Ember and it drives me crazy.
Use UiExplorer and see if there aren’t other unique selectors that you can use.
Regards
Troy
Hey @tmays
thnx bro for the suggestion.
Added some extra selectors from parent and grand parent to make it more unique. It works now with different values.
Regards
Devbrath
Hi @devbrath,
You can add parent tag & remove tag
check with uipath explorer
