Need Help regarding Attended automation framework triggers
While going through the videos on Attended Automation Framework triggers and forms in Studio (v2024.10) on Academy, I was trying to create an automation where the Start Trigger activity is used. However, I was unable to find this activity in the Activities panel. I am using studio version 2026.0.189 STS.
Could you please confirm whether Process Start Trigger is the same as Start Trigger?
Hi @vivek.srivastava
Yes, in newer UiPath versions the “Start Trigger” activity has been renamed/split into specific trigger activities like Process Start Trigger, Click Event Trigger, Keypress Event Trigger, etc. So what you are seeing is expected in Studio 2026 STS. For startstrong texting an automation when a process/application starts, you can use Process Start Trigger, which is basically the updated equivalent for that trigger scenario.
Yes they are the same.
In Academy videos (2024.10), the activity is shown as “Start Trigger” because it was introduced as part of the Attended Automation Framework to handle trigger-based execution and In “Studio v2026.0.189 STS”, the same activity is listed as “Process Start Trigger”.
@vivek.srivastava
I don’t remember the purpose of the Start Trigger activity but if it’s the first activity which starts listening to the triggers, I think you should be using Run Local Triggers activity
@vivek.srivastava
You can use Process Start Trigger activity instead of start trigger, now it got changed to process start trigger to get the knowledge on Process start trigger you can refer below documentation,
Happy Automation
