Hello. I’m attempting to write a range using the filter wizard, but it’s not writing anything down. can someone let me know what I’m doing wrong
Read range: Output Data table ’ dtCARSconfirmations
Filter: only want to keep items that start with SLS
Write Range: Output should be listed on Sheet2
I have also provided spreadsheet.
CARS TDO report_clients.xlsx (13.7 KB)
ppr
(Peter Preuss)
July 8, 2022, 3:25pm
2
we do see the ’ forcing Excel to keep it as text
Work book read range activity has not mandatory the same read range result as Excel Application Scope - Read Range
However you can quikly inspect:
set a break point on the filter datatable activity
debug and get paused
use the immediate panel and type in: dtCARSInformation.Rows(0)(“Schedule”).toString
feel free to check also other rows by changing the row index 0 to other rows
Understanding the 6 Debugging Panels of UiPath in the easiest way possible! - News / Tutorials - UiPath Community Forum
Thank you for the hint. I inspected the output in the immediate panel, and it did provide the results I was looking for.
However, how do I get my output to be written on Sheet2?
I went ahead and included the ’ under the value and the results came out good.
However, I attempted to add more values using the expression {“'SLS”,“'FTB”,“'TDA”}. No information is coming out on Sheet2. is it possible to add multiple values? if so, how?
I solved it. I added multiple rows and use the “OR” for each one.
Thank you for your help!
system
(system)
Closed
July 11, 2022, 4:38pm
6
