Hello All,
I am a RPA workflow developer so not familiar with the Ochestrator setting and role etc.
Recently, I was assigned to handle the unattended robot movement from machine-A(VM) to machine-B(VM). Machine-A is currently in production, thus want to make sure the process won’t be affected when transferring.
Background info as below
- UiPath version 2021.10 (on premise stand alone)
License as below
- unattended robot *2
- automation developer *1
I am trying to install UiPath on the machine-B(VM) but I could not successfully do it.
What I did so far:
- create a machine on ochestrator and set the machine name exactly same as the machine B
- create a User in orchestrator (necessary or not?) and assign “robot” roles to it but did not “setup robot”
and I still not able to install the UiPath with the user ID.
Can anyone kindly to share the info I needed to setup and how to manage OC? That would be a big help for me.
