I have following data on pdf which I need to extract using regex
Now the question which is “Who has access to the digital solution?” will be constant and I need to extract below options which will be dynamic value,
here you can see two options are available which are a and c but it may contain one or more options.
So any suggestion on how to extract the options using the question above with the help of regex?
