Instead of selecting the aaname=“*”
You can try with innertext
Regards
Gokul
Do you know what word will be there prior or in runtime before that step you need to click ?
Regards
Gokul
@Gokul001 No that is why this all is happening otherwise if I know the word before then I should have simply use the click activity and pass the aaname as the text which will be there.
Okay so the clickable value will always below the Customer right?
Yes, It is working for me but it has IDX in it as i remove the idx it is not working so i think i need to go with IDX.
In some rare cases we have to use IDX(If it is fixed) as there is no other options/properties available.
Even I had face the same issue while clicking the next month calendar button ie, > .
My selector
Its running everyday and working absolutely fine.
Yes Karuna @Karuna, I agree with you.
Even I have used the IDX in some the cases and those are running fine.
I was finding if I am missing or doing something wrong and if the forum folks have any better approach/idea. But its look like, we can deal this with the help of IDX.
Also, my IDX is stable it is not changing so I should be good. Lets see.
Thanks @Karuna.
