Need help,
Hi @Ravi_Shirsath !
Do you mind explaining where you are blocked ?
- Is there an error message and you need us to help on it ?
- Is there something you did not understand in the instructions given and you need us to explain a little bit more ?
Yes like the input sheets has full string which i need to loop but in another sheet only some context so i don’t know how partially i can match string
Sorry my organization don’t allow option for sharing thank you
@Ravi_Shirsath Check this below workflow attached,
Uipath_PartialMatchFromString.xaml (13.9 KB)
and also input file which I have used
Input.xlsx (11.2 KB)
Hope this may help you
Thank you for your help
