A Hearty Gratitude to all my fellow counterparts,
I need your guidance regarding a project; that I am presently working on . Let me illustrate the situation.
I have a customer “A” and who has a B2B portal; where the customer shares important reports (customer ratings).
I have build a bot in such a way that the BOT extracts the customer ratings from this B2B portal automatically. This has been done by me for one of my plants.
Scenario: We have different plants located in different parts of the country and for each plants; we are receiving customer ratings from customer accordingly. Moreover, each plant has their respective “User-ID” and “Password”,
For instance:
Plant A Customer Rating: “100 %” User ID: xxxx; Password: yyyyy
Plant B Customer Rating: “100 %” User ID: zzzz; Password; uuuuu
Plant C Customer Rating: "80%) … and so on
Plant D…
Plant E…
… and so on.
Problems: I have created a BOT for one plant only(with an user name and password) and it works fine also for other plants (with different user name and password), if I am running it one after the other.
However, I want to build a workflow in such a way that BOT automatically enter the user name and password for one plants and then pick the customer ratings for one plant and then BOT go out of B2B portal and then again BOT automatically enters the user name and password for other plant and then pick the rating accordingly. This is an iterative process; which should happen for 22 times, as I have 22 different plants with different user names and password.
I ll try to simplify the above problem in the following steps;
-Bot opens the B2B portal
-Enter the user Name and password for 1st plant
-Picks the customer rating
.-CLose the B2B Portal
-Bot again open the B2B portal
-Enter the user Name and password for 2nd plant
And the same process continues for the remaining plants.
Kindly support me, how can I proceed further, so that i can build only 1 Workflow rather than 22 different workflows (1 for each plants)
YOur support would be highly appreciable !!
Thanks & Endeavors
