Namespace not found... my process does not work when I close and open Uipath
I have an issue with my process which is nit working.
Yesterday I have used the recording function to record some actions on my desktop, but this morning when I oppened my PC i found an error saying that “this activity is either missing or could not be loaded properly”.
For information, I 've recorded actions on outlook (clicks to open and save emails). I know we can use by making some parameters, the background outlook but I don’t want to use this one for some reasons.
This is what appears :
Could you please tell me how to fix this problem and also how to avoid having the same error tomorrow?
Thanks
@dalilasencha
Bon Jour
Do a restart of the machine (the first save aid action)
if issue still occurs then check dependencies in the dependency manager
I have just restarted the machine but problem remains…
How/where can I check the dependencies?
and also what is reallys trange is that I don’t have the activities (recording…) anymore… image
click on manage packages (refering to your screenshot from above)
Ah okey sorry, yes I see what it is… well I have already used this and installed this package
The problem is about the recording functionality, everything was recording and I only used simple clicks…
can you rerecord instead?
this what i have done… i recorded the process
Can you check your dependencies and verify that in case of outlook automations also
  • UiPath.SystemActivities
  • UiPath.Ui.Automation.Activities
  • UiPath.Mail.Activities
is referenced
and UiPath.Ui.Automation.Activities not found… I only installed UiPath.Mail.Activities
Click on official (Packages) and start search with term: UiPath
It worked with UiPath.SystemActivities !!! many thanks for your help
Great :slight_smile:
Happy Coding
i would need another advice… I am trying to open this file (I have tried recording, the enter option, double click image…) nothing workS… do you have any idea of how to do this?
I just need to open this ppt
@dalilasencha
Give a try on:
Start Process and pass the filepath of the file as an argument
