Hi could you please help me to find why the excel file invoice template is not displayed in get text discount as the tutorial mentions?
In my case it displays no options found…I do not get the indicate in excel as the tutorial says
@Valv ,
You can use "read Range Activity " to read the excel file instead of using get text
You will get it as a table
Hello @Valv
Are you trying to do some automation in Excel? If yes, UiPath is providing the Excel package to support excel automation. You can use that instead of using UI-based automation.
Thanks
Thank you all for your replies🙂
