@WhenCutEsh This did not work either
@ColinCrabtree Let me debug your code , can you try one last attempt by giving a delay of 3 seconds in the delaybofore property of the click activity and remove the simulate click option.
Fine
it looks good actually but may be we can go for a trial and error method
this looks wierd but sometimes work like we can use a HIGHLIGHT activity before to the Click activity and select that drop down as element with that highlight activity
–so that the bot will try to highlight that element, and if its able to highlight it should be able to click as well
hope this would work
Cheers @ColinCrabtree
@ColinCrabtree As far as I know The code is being executed before the element is actually around, Try using FindElement follwed by click and remove the Delay, I had the same issue and just referred my workflow and saw where was it going wrong.
@WhenCutEsh - I tried this as well and it work perfectly. I prefer this solution to the one you provided using the delay as it seems more robust and reliable. - Thank you !!
