i am using Appium 1.20.2
1.20.x is broken for MobileAutomation activities. Try 1.21 or anything older between 1.15 - 1.19.
i downgraded to 1.15.0 . still not able to connect . Getting below error.
A session is either terminated or not started
Thank you very much , i was able to connect . i had given time out , which i removed and it worked
@phaserescu Hi Cristian,
I was facing the issue for appium 1.20.2 now i downgrade to 1.15.1. but now it is keep connecting. not showing any logs or error. can you please tell me where i can see the actual logs like we can see in appium desktop app.
Iâm not sure if in this state the logs are available in MDM (DEBUG LOG section). If you manage your appium server, you should see the logs in the console or you can even start appium using the Appium Desktop App and see the logs there.
I tried to see the logs in desktop app, but problem is it is starting the 1.20.2 server there⌠and showing same issue.
So how do you start the 1.15 appium then?
Through cmd
so your logs should be on the console, in the cmd window you start appium.
@phaserescu It installed the file in emulator app but connection got terminated.
Here it is getting failed it seems:( attached are the full logs)appium-server-logs.txt (29.3 KB)
[WD Proxy] Proxying [POST /session] to [POST http://127.0.0.1:8200/wd/hub/session] with body: {âcapabilitiesâ:{âfirstMatchâ:[{âplatformâ:âLINUXâ,âwebStorageEnabledâ:false,âtakesScreenshotâ:true,âjavascriptEnabledâ:true,âdatabaseEnabledâ:false,ânetworkConnectionEnabledâ:true,âlocationContextEnabledâ:false,âwarningsâ:{},âdesiredâ:{âplatformNameâ:âAndroidâ,âplatformVersionâ:â11.0â,âdeviceNameâ:âemulator-5554â,ânewCommandTimeoutâ:300,âshouldUseCompactResponsesâ:false,âelementResponseAttributesâ:ârectâ,âautoWebviewâ:false,âautomationNameâ:âUiAutomator2â,ânativeWebScreenshotâ:true,âappâ:âhttps://uipathtestappsto.blob.core.windows.net/testapps/TheApp.apk"},âplatformNameâ:âAndroidâ,âplatformVersionâ:â11.0â,âdeviceNameâ:âemulator-5554â,ânewCommandTimeoutâ:300,âshouldUseCompactResponsesâ:false,âelementResponseAttributesâ:ârectâ,âautoWebviewâ:false,âautomationNameâ:âUiAutomator2â,ânativeWebScreenshotâ:true,âappâ:âhttps://uipathtestappsto.blob.core.windows.net/testapps/TheApp.apkâ,âdeviceUDIDâ:âemulator-5554â,âappPackageâ:âio.cloudgrey.the_appâ}],"alwaysMatchâ:{}}}
[WD Proxy] Got response with status 500: {âsessionIdâ:null,âvalueâ:{âerrorâ:âsession not createdâ,âmessageâ:âio.appium.uiautomator2.common.exceptions.NoSuchDriverException: A session is either terminated or not startedâ,âstacktraceâ:"io.appium.uiautomator2.common.exceptions.SessionNotCreatedException: io.appium.uiautomator2.common.exceptions.NoSuchDriverException: A session is either terminated or not started\n\tat io.appium.uiautomator2.handler.NewSession.safeHandle(NewSession.java:57)\n\tat io.appium.uiautomator2.handler.request.SafeRequestHandler.handle(SafeRequestHandler.java:41)\n\tat io.appium.uiautomator2.server.AppiumServlet.handleRequest(AppiumServlet.java:261)\n\tat io.appium.uiautomator2.server.AppiumServlet.handleHttpRequest(AppiumServlet.java:255)\n\tat io.appium.uiautomator2.http.ServerHandler.channelRead(ServerHandler.java:68)\n\tat io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:366)\n\tat io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContâŚ
[W3C] Matched W3C error code âsession not createdâ to SessionNotCreatedError
This is appium version
Here is configuration:
Note: It is working fine with any cloud based emulator saucelabs, Issue with local appium server
Iâm not sure, whatâs going on. You can also see the device logs issuing adb logcat
to see if something helpful is written there. Also downloading the app and manually installing it with adb install .../path_to/app.apk
and then starting the app on device to make sure it works on your emulator.
Hello, I am facing an error while starting an application in Uipath mobile Device manager. The error is " A session is either terminated or not started(session not created) ", All components are running and I successfully connected my device to Appium but when I trying to connect using the mobile device manager my Appium automatically disconnect from my device.
Hi Rahil, I am also facing the same issue. Could u please show where to give timeout. Screenshot is appreciated.
Thanks
Sumesh
Thanks,
updating Appium solved my problem
getting the error while installing the platform tool command in cmd prompt.
i have used the ApI level 30 because my mobile device is android version 11 so
command - sdkmanager âplatform-toolsâ âplatforms;android-30â
i am getting this screen while connecting my physical device with uipath
any help will be deeply appreciated
Look in the Appium logs to see if the session started or not. It might be that the session start returned an error for some reason but MDM didnât picked up on that.
Hi @phaserescu i am attaching all the screen plz help me
application is opening in mobile but not in uipath.
i am trying mobile automation for the first time
screenshots:
