Even I am using the same
What might be the issue?
Are you enable USB debugging security settings
For This you need to create Mi account
try turn on/off the USB debugging and then selecting either of MTP/MIDI. MTP worked for me.
Select MTP/First and then turn on USN Debugging.
Try above step vice versa
Check this link. This is guy is resolving device not found on MiPhone
Tried all the other ways too but no luck
I am trying to use this package. I connect Android Studio with Appium. I cannot connect Appium with UiPath Studio. I add a device and one aplication, but canât connect. The error is: âUnexpected error. The URL '/sessionâ did not map to a valid resource".
P.S.: I canât go to the address âhttp://localhost:4723â on Google Chrome for example. See the pictures please
Appium url should be like this http://localhost:4723/wd/hub
in your screenshot where you create Application⌠App section look is empty
Thank you for your answer. What do I have to put in App section, to open contacts app?
You should put apk file in app section.
contacts app is system app .I donât think we can put in app section.
I didnât understand, can you show me an example?
Having Following error in Uipath :
Encountered internal error running command: Error: The instrumentation process cannot be initialized. Make sure the application under test does not crash and investigate the logcat output.â
Please Help me
Solve This Problem by installing Latest Version of Appium 1.17.0
Installation problem
Warning: File C:\Users\A.android\repositories.cfg could not be loaded.
Warning: Failed to find package build-tools;28
[=== ] 10% Computing updatesâŚ
E:\Android_sdk\tools\bin>
hey @Ashish_Verma Can you tell me how to install build-tool package ??
Iâm also getting error in build-tool package installation.
Please help !!!
use below command line,
sdkmanager *âplatform-toolsâ âplatforms;android-28â --sdk_root=E:\AndriodSDK
Hi Sandeep,
Good Day!
Hope youâre doing good!
As per your instruction i have installed the Android SDK and Appium. When i tried to connect the server in Appium getting an error message like as below. Hence i tried open the Appium as Administrator but again getting the same issue. Please advise.
