Mobile Automation(Too Many Jobs issue)
How I Remove Jobs .
I was Run Simple Process And Run Process To test Many Time to Check This Error.
I was Facing the Error ,
How i Will Do This ,
Please Help Me Solve This issue Immediately How Cani Fix It.
you should go to the orchestrator and try to kill the job or stop the pending job.
i was Doing Tis But i didnt Solve This issue
this error occure because u had extended the use of appium url which were present in souce Lab try to change that url
Ok i will Check And Told
Thanks… its Work Finally
