Method not found error System.ObjectRestSharp.Extensions.Refelection - Solution
Issue:
Steps to follow: Solution
Please navigate to the below directories, delete the RestSharp.nupkg file:
%localappdata%\UiPath\Activities - backup the restsharp nupkg file and delete the file from the location.
%localappdata%\Nuget\Cache
%localappdata%\Temp
%userprofile% \ .nuget \ - backup the restsharp folder and delete the folder.
Now download the RestSharp package from the below location:
and replace it in packages folder in the installation folder (C:\Program files(x86)\UiPath\Studio) )
You can directly install it from Studio
Open the UiPath Studio , perform the operation.
Note: While creating the article the latest RestSharp package was 106.6.9
You can always upgrade to the latest available package irrespective of the above screenshot.
