Merge Cells in Column C if combination of Column A and B values are same
I have the data as below
I need to merge “Column C” is “Column A and Column B” are same as in below screenshot. How can achieve that? I can’t use any other packages apart from UiPath and Microsoft packages. I can use vb or c # code by invoke code activity
Hello.
Try this
Hug
Hi @Jose_Cunha
I cant use macros code because of the security reasons
Can you use external packages? If yes, try this one:
Hi @Jose_Cunha
No, I can’t
Hi All,
Anybody has any suggestions here?
Hi @Krithi1 ,
Could you check the below workflow :
Excel_MergeCells_BasedOnGroup.zip (11.0 KB)
@supermanPunch - thank you. It worked.
