Mapping Automation problem
May I know if my mapping is right?
Mapping
because when i ran this code it cause an error (Invoke Code Customize dtRawCo: Exception has been thrown by the target of an invocation.)
Dim indexRawCO As Int32
Dim columnRemoveList As New List(Of Int32)
Dim segmentName = If(segment.Contains(“RESIN”), “RESIN”,“NFM”)
For Each column As DataColumn In dtRawCO.Columns
Dim mapping As IEnumerable(Of DataRow) = dtExcelCOColumnMap.AsEnumerable.Where(
Function(rowColMap) CInt(rowColMap(segmentName+" Column Number")) = indexRawCO
If mapping.Count = 1 Then
column.ColumnName = mapping(0)(“Column Name”).ToString
Else
columnRemoveList.Add(indexRawCO)
End If
indexRawCO +=1
Next
columnRemoveList.Reverse
For Each colRemove As Int32 In columnRemoveList
dtRawCO.Columns.RemoveAt(colRemove)
Next
Dim coRowItems As IEnumerable(Of DataRow) = dtRawCO.AsEnumerable.Where(
Function(row) Int32.TryParse(row(“Item No”).ToString,Nothing) And
Not row.ItemArray.Skip(1).All(Function(item) String.IsNullOrEmpty(item.ToString)) And
Not row.ItemArray.Any(
Function(item) item.ToString.ToUpper.Contains(“FIXED”))
If coRowItems.Count > 0 Then
dtRawCO = coRowItems.CopyToDataTable
Else
dtRawCO = dtRawCO.Clone
End If
Try Below code I have made few changes for better stability
  • Initialize indexRawCO to 0.
  • Add () when calling Reverse.
  • Ensure TryParse is used correctly with the return value.
  • Add a check for valid column indices when removing columns from dtRawCO.
Dim indexRawCO As Int32 = 0
Dim segmentName = If(segment.Contains("RESIN"), "RESIN", "NFM")
        Function(rowColMap) CInt(rowColMap(segmentName + " Column Number")) = indexRawCO
        column.ColumnName = mapping(0)("Column Name").ToString()
    Else
    End If
    indexRawCO += 1
Next
columnRemoveList.Reverse() ' Added parentheses
    If colRemove >= 0 AndAlso colRemove < dtRawCO.Columns.Count Then ' Check bounds
    End If
Next
    Function(row)
        Dim itemNo As Integer
        Dim isValidItemNo As Boolean = Int32.TryParse(row("Item No").ToString(), itemNo)
        Return isValidItemNo AndAlso
               Not row.ItemArray.Skip(1).All(Function(item) String.IsNullOrEmpty(item.ToString())) AndAlso
               Not row.ItemArray.Any(Function(item) item.ToString().ToUpper().Contains("FIXED"))
    End Function
If coRowItems.Any() Then ' Used Any() instead of Count
    dtRawCO = coRowItems.CopyToDataTable()
Else
    dtRawCO = dtRawCO.Clone()
End If
