There are often automations where we have to use image recognition and coordinates in order to navigate in the target application. This makes the resolution and color depth important.
Currently, those are set for the Robot - which means that Robot cannot run two automations that have different resolution needs.
It would be great if the resolution etc settings could be set in the Process instead of the Robot.
